I feel the original poster has exhausted all he knew to make the printer to work again. The first response from this forum (post #2) was absolutely correct and every word was brief but absolutely clear. It was an excellent advice in my opinion. If I were a novice I would have followed it with caution and asked questions as I go for it. The chance would be very high the problem be solved.
Your first response was do not attempt to clean the print head by removing it from the printer.
Then your next response had long words talking about removing the print head and do this and do that.
I think this is exactly what is going to cause a novice to be confused and lost. So if the original poster were not a novice would you have said otherwise to go ahead to remove the print head with caution to clean it?
We both were trying to help others. I am surprised that we are so different. I believe in that it is necessary to remove the print head to soak briefly in order to have a better chance to unclog a print head.
