I just can't imagine all the problems people have here refilling OEM CLI-8 carts. In the last two years I have refilled 2 sets of carts, 25-30 times each with ease.
1. I flush out the OEM carts with water, I blow out as much water as possible by mouth over the fill hole, I then purge the remaining water using the paper towel method. I then dry the carts on my oil furance for over a week, the sponges are very dry.
2. I top fill, remove the plastic ball, ream the hole to 5/32" to accept the fill hole silicone plugs.
3. Reset the chip and put on the orange output port clip.
4. Fill the ink chamber to the top, watch the ink level drop as the sponge absorbs the ink completely to the top of the sponge.
5. Seal the vent with Scotch tape, this will stop the sponges from absorbing any more ink at this time.
6. Top off the ink chamber to full.
7. Plug the fill hole.
8. Remove the orange clip, place the output port over the ink bottle, squeeze the cartridge sides at the sponge to get 3-4 drops of ink out at the output port, this prevents overfilling the cartridge (very important).
9. Put orange clip back on done!
Never had any problems at all, no ink leaking, air problems, clogs, etc. with my PRO9000 MK II, I do use OCP ink.
I don't even think about refilling issues anymore, takes me about 15 minutes to refill the 8 cartridges.
Also just a comment here, the sponges are acutally a two level sponge system, the top and bottom sponges have different densities, all my cartridges sponges are completely saturated I hardly ever see any white, if any.
Bob P.
Bob P.
Make sure to invite The Hat over if you use this. He knows how to handle the good stuff.
