giggitypuff
- May 9, 2019
- Canon G2000
Hi all,
I was experiencing severe print head misalignments with my G2000 (Color portion) which could not be fixed with manual and automatic alignment, and therefore cleaned the interiors and attempted to 'reset the printer to factory defaults' because I took the print heads out and the ink delivery tubes were emptied as a result. What I did however, was to enter service mode(I had no prior knowledge of what this did and what it was) and Windows detected the printer as "Device". Since the printer is detected as offline, I proceeded to restart the printer after a while, only to be greeted by the 5B00 error. I have then fiddled around to no avail, and various button combinations that purportedly resets the counter does not work.
Now, I am not sure if my printer is bricked, i.e. stuck in service mode. If I restart the printer, I will get the 5B00 error, but when I enter service mode, I cannot perform the following: https://www.youtube.com/watch?v=Zu_vONAEM4A
I was able to follow until the 'press stop 5 times' part (48 seconds into the video), but could not perform the actual reset because the green light remains green and does not alternate between yellow.
If I screwed up the EEPROM, it it fixable with a SPI flashing tool? I need to buy one to fix the BIOS of another motherboard anyway, and they only cost a few bucks.
I wouldn't bother purchasing a Canon Service Tool/WicReset key as I cannot justify its cost considering that there is also a severe print head issue (faded magenta and warped blue) which I guess can only be fixed if I purchase a >$50 CA92 print head for Color, in which case I may as well spend a bit more to buy a new printer anyway. However, if this printer is still salvageable I guess I will just print in black which works fine.
Appreciate any input regarding this matter.
