German Method - making the all important hole
binkie
New Jersey
I use a simple push pin that I press and turn until it is through the plastic. If I want the hole slightly bigger I use a screw eye that I screw in the hole created by the push pin. You can control the size of the hole by your choice of screw eye size. It works for me!
Binkie
iP4XXX said:
Since I use a 20 guage needle, a pushpin works perfect for making the hole. I push it in while rotating back and forth. It takes me about 5 seconds. It would not work for a larger diameter needle.
A pushpin works fine in conjunction with my 18 guage needles. I use the same method as you describe, though I take more time overall.
qwertydude
I just use a paper clip heated with a lighter. Makes a very nice and clean hole.
billkunert
Georgetown, Ky
HP Envy 5530e
I use a pin vise and a small drill bit barely larger than the needles I use.
Well, just to note the Awls arrived today are now listed for anyone who wants one...
I've not put together an all singing/dancing refill kit yet because I'm still missing an ink (cue: stock control nightmares) and resetters but all on the cards once I can figure a few things out.
