With the introduction of the named printers, Canon introduced PhotoBlue into these printers in the 6 tank models replacing the Gray ink in prior models.
Some had thought that this was to extend the Blue range, In fact Canon does hint or not at this when you read the marketing text.
In fact, what you will find is that PhotoBlue is to compensate for the lack of PhotoCyan and PhotoMagenta channels.
I will soon show how this is actually done. By introducing one channel of premixed channels they then make this a foundational color when photoprinting. As a result, the PB has a lot of importance in the midtones and not having a carefully matched Photoblue will easily cause casts.
If you test this out on gray ramps, it is very evident. The issue also rears its head on photos with fair complexions.
In fact the latest generation of printers are resorting to these tricks/avenues of advanced print engines. Properly implemented they allow more control in certain shades only when a tightly matched ink is used. Epson is also using this on their latest printers. Surprisingly, this trick was already in play in the Canon Pro-10 of 7-8 years vintage.
