Epsons Yes.....but, but,but...
B
Bo Wrangborg
Guest
However...
....my printers now resting on the landfills contradicts that.
MIS-inks or OEM - that’s not the problem.
This time I'll take measures!
I'm no longer listening to You fellows.
I'll do it my way - the new way.
What's wrong with pure water in the lines? (as described above.)
God seems to treat us different - some have blessed printers - some not!
Now I'll baptise my new one every time i leave it!
I certainly respect your decision and it’s your time and it’s your money and good advice is still free here. :smack
Speed on brother hell ain’t half full.. :woot
3dogs
Fern Hill, Australia
Epson 3880. Canon Pro 9000,
However...
Your printers are resting in landfill for but ONE reason brother - YOU
Really HATE to see a 3880 go the same way...and it will
there are inks, and inks and the 3880 thrives on Cone inks - Just remember we offered our best when you are tossing it out
B
Bo Wrangborg
Guest
Certainly - thanks for Your advices, fellows.
However - this time I'll listen to my own.
None has voted against my proposal, just suggested other ways, so it cannot be that bad!
Again - Thanks!
OK guys, I still have some free samples of antipsychotic tablets like olanzapine, leftovers from persons who have been collocated just recently....:caf.
B
Bo Wrangborg
Guest
He he....
...if not all this had happened I might still sitting there with an old EP 1280.
They call it progress!
Next time MK and PK will have separate lines and nozzles and built in ultrasonic thing in the print head.
Or?
B
Bo Wrangborg
Guest
It seems as if You yourself need them just now - reading this for you scary thread.
Was it the word "landfill" together with the EP-word that made you feel sick?
Anyhow: the reason why you do not use plain water in the printer is that normal tap water contains dissolved minerals that can precipitate in your expensive print head and secondly due to the high surface tension of water some microscopic cavities cannot be reached by plain water and thirdly plain water is an excellent medium for growing microorganism.
B
Bo Wrangborg
Guest
You wrote: Anyhow: the reason why you do not use plain water in the printer is that normal tap water contains dissolved minerals that can precipitate in your expensive print head and secondly due to the high surface tension of water some microscopic cavities cannot be reached by plain water and thirdly plain water is an excellent medium for growing microorganism.
Sure - but read the thread first!
And ... BTW - have You been in there yourself?
