guymark
I am generally speaking very happy with the 9600 and the print quality really is very acceptable for such an old machine that doesn't have the new orange, green and red inks etc.
There is one annoyance however and from time to time, it throws up "Paper Jam Error" - at which point the only remedy is to switch the printer off, clear the jam and restart.
Now that sounds fair - except in each case it has happened to me, there is no jam whatsoever, the paper has been flat, smooth, coming off the roll nicely and has nothing observable in the path. The roll is free to turn with VERY little resistance - and usually it works just fine.
If I only printed A1 and below it would not worry me too much - annoying but not the end of the world. However when it throws an error when 9 feet into a 10 foot banner, then there is a lot of wasted ink and paper.
It has done this with both a heavyweight matt paper and a coated polyester "paper". Every now and again - perhaps every eight prints or so, it will generate this error.
I have looked at the circuit for this and if it was caused by undue friction pulling it from the roll I could "fudge" the current sensing by changing the value of the load sensing resistors. But I do not think this is the issue - as even with a 45 metre roll, it pulls through effortlessly. I do not think this is a fault triggered by an over current flag - though if need be, I could certainly check to be certain.
The printer is in a room with quite low levels of lighting (I gather bright light can upset paper sensors) and, as I say, usually it works superbly - just terribly frustrating when a long print fails - especially if it has already completed most of the print as then there is considerable waste.
I have looked online and checked manuals but other than "make sure nothing in the paper path, make sure roll can turn easily and make sure room not too bright", I am at a loss as to what to try next.
I *did* see someone suggesting using a vacuum cleaner on sensor holes but I am not sure where these holes are - and as the thread was VERY old, unsurprisingly, the original poster has not yet replied to my query about where the holes in question are.
If anyone has a 7600 or 9600 and has had this problem from time to time and/or knows what might trigger what is basically a false alarm, I would very much like to have your thoughts please.
Many thanks.
Many thanks.
