Epson L800 slow printing, I tryied everithing
DavidG0209
Print Lurker
Epson L800
Bonjour, avez-vous résolu votre problème? parce que j'ai le même problème avec mon imprimante et n'ai pas trouvé de solution. Merci d'avance si vous avez trouvé une solution et partagez-la.
EDIT: Google
Hello, have you solved your problem? because I have the same problem with my printer and have not found a solution. Thank you in advance if you have found a solution and share it.
mazy_pishi
Iran- Mashhad
Epson T50-P50-R270-1410-L800
Hi based on my experience epsons P50 T50 or R270 series have the issue of sudden low speed after progressive printing.
But the problem almost solved in later upgrade of them in L800 series.
That is not the CR motor problem.
Mostly you can fix this by resetting the thermal protection in epson adjustment program.
This link could be helpful.
http://www.acroprinter.com/cr-motor/
Deion
Epson 1390
did anyone figure out what makes the printer slow down after a few prints?
L805, WF2010, ET8550
@Deion - which printer are you talking about - the L800 in the title of this thread or the Epson 1390 you are listed with ?
Run the status report of the WicReset utility - it should list up the last error conditions which are stored in the firmware. An overheating printhead is a possible cause for a slowdown.
Deion
Epson 1390
yes i have the Epson 1390 i been looking all over for a solution for this,. this thread is the closest because he was having the excact same issues as im and now, i will run the WicReset utility to see if that can help figure this out,
janina aguilar
Print Lurker
Epson 1390
Hello, This is an old thread but is the closest ti what is happening to me... Where you able to solve it?
janina aguilar
Print Lurker
Epson 1390
hello, were you able to solve it?
Gene46
Canon Mg6120 / mg7520
Here are some steps to help with your Epson L800 issue
Epson Adjustment Program: Run the CR Motor check and initialization in the maintenance section.
Inspect the CISS chip and flex cable for damage. Ensure no air bubbles in the ink lines. Run a nozzle check and perform printhead cleaning cycles. Set spool to “Start printing after last page is spooled.” Disable bidirectional printing. Ensure a stable power connection. If these steps don't help, contacting Epson support is the next best step.
