- Thread starter
- #11
- Dec 27, 2014
- Location
- Germany
I tested the L800 inks a while ago, they performed better than L300 inks but not as good as the Fujifilm DL inks at that time which are a kind of reference for me. but I did not compare the L800 and ET7700 inks directly. The ET7700 was tested together with a XP-860 which uses Claria inks in cartridges, the fading test of the c't magazine showed that the Epson 106/ET-7700 inks performed slightly better, there may be reasons other than the ink itself explaining differences in results e.g. different ink densities by the drivers in different printers. But regardless of such differences those inks perform quite equal in this test. I'm testing against the Fujifilm DL inks, in an environment w/o sun at this time, so ozone is playing the major role of the fading agent, and not UV as in other tests during summer time. Epson may actually use the Claria inks for the ET-7700 but doesn't tell their customers for marketing reasons - I don't know.
I'm not using water to dilute the M and C inks but a soft cleaner by a German ink shop -
https://www.octopus-office.de/shop/...n-for-the-inside-of-printer-cartridges?c=1295
which works fine, it is probably the solvent base for inks - without dyes, I have seen similar offers by a few other ink suppliers.
A 'clear ink' like this one may work as well
https://www.farbenwerk.com/navi.php?a=1346&lang=eng
