Epson EcoTank ET-8550: Pigment instead of Dye inks
ioprappas
Greece
Canon Pixma Pro-10S
Dear friends,
I am planning to buy the Epson EcoTank ET-8550 printer.
As we know, this printer accepts one Epson 114 BK (Matte-Black) PIGMENT ink and five DYE inks.
I'm thinking of using farbenwerk (https://www.farbenwerk.com/epson114-eng) inks and in particular Pigmera ETX pigment inks, which are all pigment type.
For this use (PIGMENT INKS instead of DYE ones) there are instructions here: https://www.farbenwerk.com/epson114-eng
What is your opinion?
Can pigment inks be safely used instead of dye inks in the printer according to the company's instructions?
Thank you in advance!!!
2x SC-900, WF-7840, TS705
Hello, you can it use it safely, BUT when you buy the printer fill the system with the pigment ink immediately and keep the dye ink bottles sealed. This way you won't mix the dye inks with pigment ink but start immediately with the pigment inks and the printhead is primed with your pigment ink. You can sell those bottles of 114 pigment inks to people who are using genuine 114 inks.
I'm currently running an ET-8550 - with dye inks - and will stay with them. But I switched various times between dye and pigment inks on various other Epson printers - like the R265 or the L800/805 or L1800 , I can report that it worked out o.k. when changing from dye to pigment inks - following a kind of similar approach as described in the farbenwerk instructions. I'm running pigment and dye inks alternatively on a small 4 color WF2010W w/o problems. I had more and longer lasting problems when trying to switch back from pigment to dye inks, incl. replacing the dampers in the printhead carriage - the cartridge like replacements in the printhead. And more effort is necessary to clean the tubes and tanks from the smallest leftovers of pigments. I would support the comment by farbenwerk to start with pigments inks directly in a new printer.
Be aware that any change as intended - swapping the inks - will void the Epson warranty so all such modifications are at your own risk.
I tested various dye inks for longevity, the best performing inks are the Epson OEM inks - 114 or 106; I couldn't find any non-OEM inks being close to OEM inks in this respect. I cannot comment on the Pigmera ETX inks by farbenwerk how they perform in regards to gamut size, black level . gloss and bronzing, there are significant differences between 3rd party pigment inks in this respect, which must always be judged in connection with particular paper types.
ioprappas
Greece
Canon Pixma Pro-10S
Thank you very much for your detailed information!!!
RiverRat01
Epson SureColor P-600
I have an ET-8550 in the box on the shelf. I have an SCP-600 that I may not be able to repair. I need to make a decision about unboxing the ET-8550 in the coming weeks. The P600 has perfect nozzle checks for LLK, LK, and PK (and presumably MK). Thus, I am currently using the P600 for B/W printing while I am trying to bring the color channels back into play. If I must unbox the 8550, I may void the Epson warranty out of the box and charge the ET-8550 with Precision Color pigment ink.
Do you happen to know what results I can expect from an SCP-600 versus an ET-8550, both running Precision Color pigment ink, and both printing on Red River Satin?
GregBrightimages
EPSON ET-8550
Dear friends,
Hi. I'm a newbie to printing in general and just got my ET-8550. Why are you not using the dye based ink? I did just get in the Epson Hot Press Bright SO42327 and noticed the warning in the box, not to use with dye based inks???
It's a matter of both the paper and the inks how they perform together, this matte paper may very well yield better performance with pigment inks - gamut and black level - than with dye inks, but I don't see another technical reason not to use dye inks on that paper.
bplaman
Epson Stylus Photo 1500W
On the Epson USA website for this printer there is a color profile for this paper. So print in good health.
Here is the link (I chose windows 10 64, bit):
https://epson.com/Support/Printers/...PT_C11CJ21201?review-filter=Windows+10+64-bit
Fried Chicken
Epson ET-8550
Epson has an ICC profile manager utility that iirc lets you change the default ICC profile inside the printer.
I couldn't find a download to even test if it would work on the ET-8550. Epson says it won't work, but they say the same thing about their Print Layout software, and that works wonderfully.
Should you switch to pigment inks and make your own ICC profiles, it would be nice to install those on the printer firmware.
