Hello, I need some advice from any of you who have an Epson pigment ink based CISS setup working successfully.
I need to set up a CISS system to print thousands of A6 retail labels.
I would ideally like to use a fairly low cost printer e.g. Epson s21 sx215 etc
The problem I have is that the previous systems I have set up tend to get permanently clogged nozzles within a month or two.
I am not sure whether the ink or the printer is to blame.
Does anyone have the same problem?
I am about to print another 5,000 full colour labels over the next month and would appreciate any advice on a good set up.
Can you recommend a printer, ciss and ink.
I am based in the UK and so need ink and printers available in the UK. The ink needs to be pigment based as the labels get direct sunlight.
Thanks.
Thanks.
