Epson 7890 internal cleaner
fineartphil
Epson 7890
There are a number of internal cleaning solutions on the market on can fill into empty ink cartridges to clean Epson k3 /Ultrachrome inks. Most of these solutions are priced in the stratosphere commanding $200 dollars or more per gallon. I am hoping someone knows the formula for making their own solution that is both safe and effective internally inside the Epson pro machines.
Larryb
Epson R3000, WP-4530, R2000
I hear that rubbing alcohol has oils mixed in. For this reason I would stay away from rubbing alcohol.
fineartphil
Epson 7890
I am finding a lot of food grade propylene glycol online, is this workable or is there another grade or type I should use???
2x SC-900, WF-7840, TS705
Hi fineartphil,
that is the right grade of propylene glycol. You don't want to use the toxic ethylene glycol.
However, the formula for the conditioning/cleaning solution is a bit different from the preservation solution:
conditioning/cleaning:
3 % propylene glycol
20 % isopropyl alcohol (IPA), 99% should be OK if the 1% is just normal water and not some additive.
distilled water up to 100 %
For extra cleaning power (dried ink and pigment particles): ad 20-25 drops (equals about 1 ml) of concentrated ammonia to each 100 ml of conditioning/cleaning solution.
The preservation solution (for storing print heads) has a increased amount of propylene glycol (explained in the link given by The Hat):
20 % propylene glycol
fineartphil
Epson 7890
I cannot thank you enough, much gratitude my friend. Hopefully I can resurrect my 7890, it shows different clogged nozzles each time I run a nozzle check. I also misquoted the cost of cleaning solutions online, at last check a gallon tipped the scales at $500. Quite incredible as it is in line with the mega bucks Epson repair/ services.
Paul W.
Billings, MT
Epson 1430 HP 932 Canon iP8720
Can you help me understand what is meant by "concentrated ammonia"? And where would I get that? I see you are in Belgium - I think these concentrations are different in Europe and the US.
Thank you!
