W. Fisher
- Aug 13, 2015
- Epsons, Canons, Brother.
I have QTR for the RIP and can change the *.quad files for QTR myself to alter the density. Just takes a spreadsheet and Notepad++ to do so, and a lot of test trials too.
The *.quad files opened in (freeware) Notepad++ identify the inks and you just have to change the values beneath them higher (more ink) or lower for less ink. Apply a percentage or multiplier like 0.8 or 1.2 to them all in that particular ink color and you are set in altering them.
I pulled the BK down (in the attached *.quad file) to about a third of what it was originally. Blacks are now blacker with less gloss differential (matte dullness) so "less was more black." Not as black as with an airbrush though which was L*=3.5, but I got a L* of 7 so not too bad over the former L*11.5.
My airbrush testing is better than the wet brushing and swabbing of the ink too. The later two disturb the RR Metallic paper's coating and it becomes magenta so it's hard to measure. The airbrush doesn't do that and is more like I'd expect out of the printer. Too bad the printer cannot replicate the numbers of the airbrush spray nor the gloss from it (No differential gloss at all!).
Surface is indeed playing into this and maybe a switch to a more textured surface might help with the DG. Maybe Inkpress Satin/Luster Metallic or the PermaJet Titanium Luster 280 Metallic, but for now the Red River Metallic Glossy will be the (cheap) test paper for the mixing of the dye inks.
Least I haven't had a clog or nozzle check go bad yet in this mixing. The "i2i Absolute Clear Ink" seems to have some wetting agent in it as it foams a bit when shaken and more than the other 3rd party inks too (Some have no foaminess at all.). PhotoFlo perhaps. I sort of worried that the slow trial mixing of the inks or the combo of i2i Clear ink might plug it, but so far so good. I thought it thickened when it got blacker when stirring it up and that it might trash the printer, but it hasn't affected it (yet).
Can't wait until I use up the first run batch and see what becomes of the second batch of C7. Should have mixed a smaller batch, maybe 30ml instead of 70ml, but the small measuring gets too tedious and critical.
Attached a less BK *.quad file to help with the differential gloss matter of the first. Call it version 2. I can see I need to add more BK to the LC, C, LM, Y tanks too from the QTR Curves it shows as they are peaking. At least the 500ml of Claria out of the Noritsu 102 cart will last for several refills of the entire cart array.
Back to a work in progress...
Will.
Will.
