Dual two color embed into an embossed / embedded text in a 3D Print?
Nifty
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
Well, I got over my fear of filament swapping (my new dry-box makes it easier since I have 2 spools loaded up at the same time) and did two tests:
I used the "Change Filament" option on the CR-10 and it worked really well!
(This custom Nameplate Generator thing)
Nifty
Administrator
Bay Area CA
FYI, I'm going to try this out next time, so instead of watching the layer lines like a hawk, I can program in the pause, let the code cause the pause, and then change the filament myself!
Nifty
Administrator
Bay Area CA
FYI: I haven't had any success with this method. When I print direct from CURA using USB, it completely ignores the pause-at-height command, but when I print from an SD card, it stops at the height, but nothing I can do will get it to resume.
:he
So, I'm back to just watching the print and manually hitting the "change filament" menu item at the right layer height. :rolleyes:
At least using that method you’re in control, I don’t use the change filament button, I just hit the pause button and pull the filament out and insert the next one and then hit resume, I’ve not had any trouble doing this so far..
P.S. You can time how long it will take to get to the changeover point by seeing how long it takes to print the first 1 mm height, it doesn’t haven’t to be exact, because an extra layer or two won’t be noticeable...
Nifty
Administrator
Bay Area CA
I could do that, but I like to move the nozzle and push out any remaining previous color so I have a clean change-over. Also, pausing has sometimes left a divit from the hot nozzle resting there and/or a blob of filament. Pros and cons to both processes I guess.
Yup! I use a combination of viewing the exact layer in CURA and then watching the mm height on the display.
Nifty
Administrator
Bay Area CA
I just watched this video with yet another clever method for dual color lettering! I might have to give it a try!
I was studying this method of embedding a second colour into a project, and taught maybe it might be a good way of introducing text into your projects without having to stand over your printer while it’s printing.
For me I would have to experiment heavily first because my CURA Slicer doesn’t support (Z Hop), so I would have to practice quite a bit to get the correct setting in the new CURA that suited me before I could try to attempt anything in two colour.
Right now I’m in the middle of everything, one printer down, another in the middle of a complete upgrade and the third that is too small to finish out making the parts for my Lamp Standard, it did do all the smaller bits but now I’m stuck again.
I will have to revisit this two colour idea later in the year when things get back to normal, whatever normal is anymore, I can already see a snag with this method, it can’t print more than two colours.. I’ll put it on my bucket list… :hide
