- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
For those that are interested I have an ip4700 with a CISS system working (well).
The main reason I wanted to mention that is I am using CISS cartridges with the ARC in them which means each time I want to print a single or multiple sheet the printer does a cleaning cycle.
Because of the ARC chip the printer registers new cartridges each time on power up hence the big clean, but as mentioned earlier it will do a wash and shave in the middle of a print job quite often, but it also did that with new OEM cartridges as well.
I just couldnt possibly afford to run this printer on Canon inks.
I have an ip4300 with CISS and ink monitoring turned off, rarely doe it a cleaning cycle that is noticeable likewise my ix4000.
So I have two printers with ink monitoring off and one with ARC the rest with OEM cartridges (top fill) and reset, the only one that washes more than a cat is the ip4700.
Meow..
Meow..
