Cool trick! How to do nozzle checks as a scheduled task
crenedecotret
Glad to see the info is still being used even if I posted it a long time ago!
If you are leaving for four months, I would recommend you get a small UPS to keep your computer/printer up and running should there be a power failure while you are away
Bufoto
Hi,
I've been using your "tool" for some years with my Epson 1400 printer. It works great!
However, now I recently bought an Epson R2000 printer and I wanted to create the same batch file, but I cannot.
The reason is that when I set the printer to pause, the Epson sortware recognizes that and it won't send the print nozzle check command.
Do you know of a way how to solve this?
Tudor
Cluj-Napoca, Romania
Epson L800, 1400; ML-2165W
Try disconnecting the printer from the computer, or turn it off (don't put it on pause). I don't have an R2000, but I installed a virtual R2000 and this works on it.
Bufoto
Thanks Tudor, that did the trick!
Now I can use this trick again with my R2000.
Roger in Phuket
Canon MX328
I was looking for a way to do scheduled nozzle checks on my printers..
<snip>
NET USE LPT3: \\LOCALHOST\IP4500
COPY /B IP4500.SPL LPT3
NET USE LPT3: /DELETE
<snip>
I joined up to post this message! :)
Thank you, crenedecotret, for this useful information.
My command file contains this, but does the same job:
NET USE LPT3: \\DESKTOP\CanonMX3printer
COPY /B "C:\S\Printer Tests\PrinterTest\00004.SPL" LPT3
I run this when my PC starts.
Welcome to the forum, Roger! :frow
Thank you for your contribution, too!! :thumbsup
Roger in Phuket
Canon MX328
Hi stratman!
Based on the method of crenedecotret, I've also written a command file to turn off the printer before I shutdown the PC. :)
The Canon MX328 has a command to turn it off which can be sent using Canon's "My Printer" utility. So I copied the files on the print queue after I sent the "Off" command, and made a command file to copy the .SPL file to the printer so it turns off.
I've combined that with the nozzle check command so the last thing I do is a nozzle test print and then turn it off. :)
I did not know printers had software commands to turn themselves off. Cool.
Roger in Phuket
Canon MX328
Me neither :) I was very pleased to see the command in the "My Printer" utility. Pity there's not a "Power On" command! :
