Redbrickman
- Dec 27, 2010
- Location
- UK
- Brother MFC-L8690-CDW
Mmmm...the ones who use the German method are more brainy than the ones who use the top fill method
Well so you don't feel too inferior as a top filler let me relate my disaster from last night.
As a convert to the German method I prepared to refill some carts.
I use the SquEasy bottles and proceeded to open a new bottle of black ink. I screwed on a new cap and needle and gave a gentle squeeze of the bottle to test the seal.
Whoosh....ink everywhere, including all over my hands which of course being a clever "Durchstich" refiller club member were not protected by gloves, because German method refillers never spill any ink
After mopping up I could not see any obvious cause of the leak except the needle looked to be at an angle. I had a spare cap which then got pressed into service and all went well afterwards.
So the moral of the story is, when you think you are clever and a member of the higher "intelligencia" refillers club, just remember ink makes a mess when it spills, so be prepared. Luckily all was contained in the sink and SWMBO was none the wiser to the Torrey Canyon disaster that had occurred earlier.
For those who suffer from technicolour hands after a fill, I recommend a Pumice stone to remove the ink. Just put your hands under warm running water and gently rub the inky parts with the stone. Note I sad gently, as otherwise you might as well use Wet and Dry abrasive paper
Please also purchase your own stone, as otherwise you will leave behind the evidence, as I did
