- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
Yes is the answer you can over ride the Cartridge prism just like in the old chip-less BCI-6 cartridges.
On those printers if a cartridge showed empty and it was removed but not replaced with another one and the slot remained empty.
Then the printer would be completely fooled by this action and will carry on printing regardless and be unaware of the consequences. (Enter the Chipped cartridges)
While your method of partially filling the reservoir with just enough ink to cover the prism
and then resetting the chip will work it doesnt however fool the printer at all.
It will show low ink just as soon as the reservoir is empty and the chip will drop to that level also, however if you reset the chip once more this time the printer will ignore the prism and run the cartridge dry..
Tudor's test results in post #17.
