ivanalbright
- Apr 3, 2010
I have an epson workfoce 610 with a CISS that looks exactly like this one:
http://www.youtube.com/watch?v=3vmScQRfIso
I've been using it about 6 months now and it has been mostly okay. It has always given me random "cartridge not recognized" errors (once every 50-100 pages or so), which I was able to fix by just removing then re-seating the cartridges.
However, the last time this happened the ink does not appear to be flowing from the tanks to the cartridges and nothing I have done seems to fix it.
Problems/Observations
--When trying to print, only the blue is working properly (other colors come out just a little or not at all)
--I can see there is now air in the tubes toward the cartridge end.
--The ink tanks are at the same level as the printer as instructed and I didn't move them.
--When re-seating the cartridges I did have to lift them up a few inches, but I've done that many times before with no problem.
Things I have tried during troubleshooting without success:
--When I lift the ink tanks up above the printer, the ink flows into the cartridges and the air in the tube disappears. I've then tried printing with the tank still above the printer but nothing changed. When moving the tanks back to printer level, the ink flows back out of the cartridge and the air bubble reappears
--I've tried pulling the whole thing out, setting it on a tray, removing the plug on the cartridge and on the ink tank. This let ink slowly into the cartridge and after 15-30 seconds ink started coming out of the cartridge's plug hole which I quickly re-plugged. However when I put everything back into the printer the air in the tubes had reappeared and the problem was not fixed.
In reading about this, I heard some mention of clamping the tubes then doing something else to re-establish a vaccuum. It sounds like that may be the problem here? The explanation wasn't good and I'm not sure exactly where to clamp or what to do after clamping.
What should I try next to get this working again? Thanks for any help!
