- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
foxx333
As I said earlier you keep getting different error codes but they all seem to be correct.
I am just wondering if something is just loose, or maybe the previous
owner dropped the printer somehow while moving it.
The code 6502 usually means a cartridge error so are you sure that all of your cartridges are ok
please check them again on your computer screen. (no error reported)
Now you could try this procedure and see if it works for you.
Please read and follow this procedure carefully.
(1) With the printer off press and hold the power button.
(2) While still holding the power button press the resume button twice.
(3) Release the power button, now this may work without any further intervention.
There is another procedure that may also help but only use it if the above one doesnt work for you.
(1) Follow the same steps 1 and 2 above only and then add these extra ones below.
(2) When the green light is on continue holding this button in dont let go.
(3) Now let the resume button go then press the resume button twice.
(3) Let the power button go, then press the resume button four times.
(4) Now wait till the printer is inactive, if the power is off then turn on the printer normally.
(5) If the printer will not respond to the power button then pull the power plug and wait about 20 seconds,
put back in the power plug and turn on the printer.
Hopefully one of these procedures will work for you and the printer will work normally again.
