- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
I found out that Windows Paint can do the same color sampling as Photoshop. I checked the picture uploaded by turbgyu and got the same RGB values of 120-120-120 for both tile A and tile B. But in the picture I printed and cut and scanned, the tile A was RGB 116-121-125 and tile B was RGB 124-129-132. So stratman was right about my picture. The printer and scanner used was a salvaged HP All-in-one under repair and cleaning, so not the best printer and scanner.stratman wrote:
They are not the same shade of gray. Tile A is slightly darker, though it may be an artifact of your snip and scan. (Yes, I blocked out the rest of the image to compare the tiles so as to not be influenced by other colors or luminescence.)PeterBJ wrote:
From this scan it is seen that the two squares really are identical in color:
I "knew" that the tiles were identical so I couldn't see the difference. After being told and having measured the tiles, I can also see the difference. I think the difference is small, so stratman must have a very good color sense to spot the difference.
