Mariya - This forum has people helping you whose advice will be the best for fixing your problem. If you can't solve the problem with the pigmented black nozzles and all the other nozzles check out OK, change the paper type from plain paper to Matte (or Matte photo paper if that is how the paper type is shown in your driver software). Print one text page and see if it is satisfactory. The pigment based ink is only used with the plain paper setting so you will be using all the other colors to create black text. I have a Canon ip5000 that has a less than perfect nozzle check with the pigmented ink cart. It is, however, an excellent color printer. I just treat it as if the pigment ink cart isn't in the mix, and it all works just fine.
