Trigger 37
- Dec 23, 2006
lin,.. what I noticed when I fixed my timing strip was that none of the items I fixed were visible. I could not see the problem of the grease on the timing strip until I held the light in a different angle, then the grease smears were visible. Once I took of the entire timing strip and cleaned it from end to end, I finally got all the grease off and resolved the problem. If you are still having 1mm of offset, there is something more on the the timing strip.
