mikem65d
- Oct 2, 2014
- Canon Pro-100, ip6600D, i900D
Started going bad last weekend. Did a nozzle check and only one stripe. Took the PM cartridge out and dribbled Windex on the inlet of the PM port...........let sit for a day, checked Nozzle print again, no change.
Then filled a cartridge with Piezoflush, did a few head cleanings and then let sit for 48 hours. Did another Nozzle print and looks like this now. Repeated another 48 hour soaking, then today see the same result.
Have taken the head out and started soaking in Windex............injecting some pharmacists liquid thru the ports flows nicely thru other 5 channels, but PM is flowing in an odd manner like this way and that way directions.
Upon deciding to put this printer away (started using before i had planned cuz son wanted to try fire it up and promised to print regularly but didn't) i started flushing all the cartridges to put away. When i go about this i pull the clip off, then pull the fill plug to watch the ink flow. The PM was of course the only one that refused to give it up unless i applied pressure to the cartridge. This tells me i probably killed this head by not checking this before i installed it a couple weeks back ( i normally do check my carts but forgot to this time), but i would appreciate your input as to whether you think i should continue to try with this head, or just chalk it up to experience and toss it in the scrap pile.
