- Jun 16, 2006
- Location
- La Verne, California
- Epson WP-4530
There are basically two approaches to cleaning a print head outside of the printer. One is to flow a cleaning solution over or through the print head and the other is to soak the nozzles in a shallow pool of cleaning solution. In my previous post, I described an example of the first approach but here is a safe method to perform both approaches without removing the print head from the printer:
Open the printer cover and wait for the print head to come to a stop in the center.
Remove the cartridges for the colors you want to clean.
Put a drop or two of Windex on the screen inlets in side the print head.
Replace the cartridges.
Put some Windex on the purge pad off to the right where the print head parks.
Make sure the Windex does not drain away.
Close the printer cover.
Unplug the printer without turning the printer off or doing anything else to it.
Let the printer sit for a day or overnight.
Plug the printer in and do a nozzle check.
Repeat many times.
Note: the iP6000D is different from most other Canon printers. If you open the cover after you have been printing and put Windex on the purge pad, it will remain there. If you close the cover, wait for activity to stop, and open the cover, the Windex should be sucked away. If you then put more Windex on the purge pad, it will immediately be drained away. This is unusual. For every other Canon printer that I have done this to, the Windex will not be drained away. So for your iP6000D, it is very important when doing this cleaning technique that you make sure the Windex is not drained away. If it is, do a nozzle check and then start the process making sure that you only open and close the cover one time.
One of my iP6000D's has many clogged nozzles. I will try this approach and report back in many days.
Repeat many times.
