Canon ip4300 dead and ip4500 Dying
Seems I checked the forum at the right time...
Ok... I have one thoroughly clogged but useable iP4300 sitting on a shelf looking for a new home so if you want it, 20 to cover postage + a small beer, and it's yours..
As for the iP4500, depending on where you've already ordered from the best place is CRC-Tasktron which is the Canon service centre in the UK. I've not found genuine, new parts for cheaper and they are not of the "Oh! you used *spit* other inks?! We can't help you at all" ilk but they might smirk a little ;)
Beyond that I've also got in some printhead cleaner from Image Specialists specifically for the Canon and other Bubble/Thermal printheads so I can chip in a little of that with the iP4300 for you to play with.
Ill take the 4300 if it is still available but you have to buy your own beer.. :)
Defiance
Hiya's,
Going through a hard stage in my life, but i want to save some precious pictures and videos to dvd/bluray etc
I have got the head on the 4500 working to a decent degree
But i have a new problem ............................
The cd tray is the 'F' type (same as my old 4300 tray)
I loaded canon cd labelprint etc and the 4500 shows as only and default printer attached etc etc
But when i try to print onto a disc it's as if the tray won't go in or be pulled in anywhere near fully
The result is printing takes place on approx 12mm or so of the inner part of a disc (as the discs are round (of course) the printing just takes place on a fraction of the tip of the disc, the rest gets printed onto the top of the inner/first inserted part of the tray
Any ideas ???
The 4500 was used by my ma and i desperatley want to get it fully working
Hope it makes sense
Many Thanks
Tony
ps: searching like crazy but really can't find anything
pps: after botched disc print attempt, the tray doesn't eject as normal (maybe there's a way to reset the cd tray alignment etc ?? )
Defiance
Hiya,
I'm sure something has either gone into the printer and is jamming whatever grabs and draws in the tray, or something has come out of alignment (maybe due to foreign object etc, really i dunno)
After yet again printing a fraction of the tip of a disc and then carrying on printing on the upper (inserted) tray, i do notice a notchy/jiggy kind of tray exit movement
Deffo not being grabbed inwards, and jerky coming out, even though the actual tray movement is minimal
Cheers for the link though
And as i type, i've just forced the tray in and out then back in, last ditch attempt so i'll give it a try lol
Cheers
Tony
Defiance
Hiya's,
My gawd
I fixed it
With the printer on, i slid the tray with disc on inwards pretty much as far as it would push
Then i withdrew it
Then put tray back in again almost as far as it would go
Left tray slammed in the printer
Hey presto, hit print on cd labelprint
Printed like a good'un lol
So i guess with a 4300 or 4500 putting the tray almost fully inwards helps the guide/innards/wizardry stuff re-align/reset
Anyways i chuffed i can print discs again :)
Cheers
Tony
