Canon ink compatibility
wizzard
I have refill ink bottles left from my last Canon S520 printer which is broken. The cartridges were the BCI-3 type ones. The black ink is pigment type.
Can I use these inks for my Canon ip3500 ones or is it likely to cause problems?
thanks
No you cannot, but installing the CLI-8/PGI-5 cartridges from a IP3500 into a S520 is possible. So the cartridges are only backwards compatible not upwards, because the new printers are using chipped cartridges.
wizzard
I am talking about using the refill Ink and NOT the cartridges.
Ohh sorry, just misread it.
Sure you can, but there will be some colour shifts.
wizzard
Thanks. I do not intend to print photos but just colour pages etc. from internet. I was not sure about using the pigment black ink which I have as I am not sure if the 3500 black is pigment or not. Also was not sure about the printhead getting blocked. I may be wrong but guess the Canon inks must be compatible with different canon printers.
The larger PGI-5Bk is certainly pigment based, so you can use this pigment ink. I use the same pigment KMP ink for both BCI-3 and PGI-5 based cartridges and no problem at all.
wizzard
Thanks! You just andswered the question I was about to ask!
