I just inherited an i9900 from a friend and I'm trying to set it up but I'm having an issue when I try to run an alignment. I'm assuming the goal of the alignment is to find a rectangle in each column that is more or less solid, but when I run mine, columns A, B and D are all just vertical lines... no solid box. +7 to -3 all look exactly the same. I tried cleaning the print head, running the cleaning utility, etc. but still having the same problem.
Also, when I run the nozzle check rows 6R and 6PM only print half the rectangle. Top half of the row is just white (nothing there) and bottom half is their respective color. All the others are fine.
Any thoughts? Thanks.
