- Thread starter
- #11
- Sep 10, 2007
- Location
- Laramie, Wyoming
- Canon i960, Canon i9900
First, let's see if you do something without opening the case...
With the power on, open the cover and let the printhead assume the "Change Cartridge" position, then pull the electric plug out to keep the head there.
With tweasers, remove the ceramic purge pad from the rubber "surround" where the printhead parks. It's on the far right side and is probably black from ink. This pad is about 5/8" x 5/8" x 1/16" thick. Don't drop it or you may be committed to open the printer to retrieve it.
Using Water and Windex, clean the old ink out of the ceramic pad. It should be nearly white when clean. Clean out the rubber surround area with a q-tip's moistened in Windex. Allow the rubber to dry.
Dry and Replace the ceramic pad, using the tweasers to coax ALL EIGHT little rubber lips over the top of the ceramic pad.
Plug the printer back in and close the cover. Let it do it's "thing" on cleaning.
Reopen the cover and let the printhead center. Closely examine the ceramic pad with a bright flashlight. You should see 6 colored bands on the pad from ink pulled through the printhead.
If not, do a deep clean and re-examine the ceramic pad, you should see a LOT of ink on the ceramic pad.
If not you probably do have a purge unit issue.
Let me know what you find.
