- Thread starter
- #11
I recleaned the printhead after discovering that the first cleaning was not complete. I again employed the large filler syringe by directing isopropyl alcohol at the absortion pads and at the jets. The process took over an hour until there was no bleeding of dye from the jets. I then popped a new cheap set of cartridges from Accstation on Ebay. After one simple purge cleaning in the printer, the results were completely satisfactory. These are the cheapest cartridges I have ever purchased, and I had purchased them to use them only as cleaning units that I intended to fill with alcohol. After seeing the results, I have changed my mind for the time being. A double set of 10 cartridges cost me only $14.99, including S&H. I still have my new refill ink from InkProducts but will wait until these run low before attempting a refill.
I went ahead and purchased a Pixma MP500 from NewEgg in case I was unable to rescue this i860 unit. I am more than a little relieved that the cleaning results have been this satisfactory so far. I would advise anyone who refills ink cartridges to replace the cartridges and clean the printhead once a year to prevent the clogging problems I had with my printer. The i860 seems to be the last of a "breed" that has both parallel and USB connection options. I am able to connect both of my computers to the same printer without networking. I hope I can baby this unit for a while longer.
One additional note a bit off topic is that photos always print better with my Kanotix Linux setup than with Windows XP. The color syncing with XP has proved to be a real pain with near black hues being a disaster, but Kanotix Linux has had no problem matching the outputs of printer and monitor. I thought it was an i860 problem, but my cheap Epson CX3810 that I purchased for scanning gives virtually identical results to the i860.
