I have tested the power supply in a friends printer now and it works.
So the power supply is fine. My printer switches on for 2 seconds then off, what can cause this now ?
It may be your print head that is broken. Remove the print head then try to turn on the power. If the power stays on it t is the print head that has something wrong with it. A defective print head can cause power to be shut off by the printer.
You have a printer that is sitting on its side? That's not good. You must mean something else. All you have to do is open the cover that allows you to change cartridges. After the carriage moves to the center, remove the cartridges and then lift on the grey (I think) lever on the right side of the carriage and then pull the black (I think) tab on the right and pull the print head out and up. Put the grey lever back down so that it doesn't get smashed when the carriage moves back to the right.
Well I have solved one thing. I now have to buy a new printer.
The damn print head melted into the purge section. All the plastic melted even the head carrier.
Yes there is. Do not leave your printer power on. Switch the power off at the wall socket.
This printer was off, but the wall socket was on all the time and some how the thing overheated. I was just glad that it did not catch alight.
