stratman said:
Just curious... it is assumed that Canon uses a two-pronged approach to monitoring ink levels:
1) Counting the number of sprays done to guage when the cartridge is empty
2) An LED or LCD (?) light that shines into the cartridge which indicates lack of ink in the spongeless side (?)
IF these assumptions are correct, and IF one does not refill the cartridge to the same number of ml's as found in a new OEM Canon cartridge, THEN how well does the printer do in monitoring ink levels?
In other words, is it possible the reset chip and the printer think there is still ink in the cartridge when there is not, possibly resulting in a burned out printhead?
snip-
I think that I see what you are getting at. So let me say this, In My opinion, If you reset the chip when the cartage is empty, and then do not refill the cartage, but instead put that same empty reset cartage back into the printer without the adding of ink, and then continue to print until there is no ink at all going out onto the paper, then most likely you will burn out the print head for that color. I say most likely because I do not know what would really happen.
But that would be the same as if you had
not reset the chip at all and bypassed the ink level reporting so that you could continue to print with
your known empty cartage until it too actually had no ink left to put out. You would also burn out your print head for that color.
The same for resetting a half empty cartage and then putting it back in the printer without adding more ink. When it reached the point where there was no ink left to come out, and you see blank pages, your guess as to what would happen is just as good as mine. I am not about to attempt to do that just to see how the ink level would be reported.
Either way, that would be a deliberate attempt to destroy your own printer. So why would anyone do that?????? I cannot, or did not, conceive of anyone deliberately doing that. Nor can I see it happening by accident.
What I do know, is that I have had cartages run dry on the liquid ink side for an unknown period of time and was still printing at the time that I checked the ink level, and I have never ran it down to the point where it was not printing, so the sponge side does hold a considerable amount of ink even when the printer reports it to be out of ink.
But
if you happen to have a couple of unused printers on hand and would like to experiment then please do, and then report back to all of us the results of such test. I think that would be an interesting experiment.
Jack
