ILikeCanon
- Apr 26, 2015
- Canon iP7250 + CISS
I have iP7250 + CISS + dampers and i printed on it 25000 double sided A4 sheets (so it is 50000 one sided)
Of course i also have an issue with air getting into cartridges. I read on this forum that Canon + CISS always means air issue.
But in my case it is strange. Currently I have mainly problems with Yellow and Magenta cartridges. I have to remove air from them every a few books printed. The other three cartridges works very good.
But I don't understand how the air gets to these cartridges. I think there are three possibilities:
1. The CISS is not tight. But this depends on the quality of CISS and therefore is fixable.
2. The air gets from space between printhead and cartridges. Most forum users thinks that way.
3. The air pass through printhead to the cartridges (for example during cleaning)
The question is if we assume that point 1 is not a problem, which from 2 and 3 makes issue and if it is possible to fix it? For example using some in-cartridge damper or glueing cartridges to the printhead?
What do you think?
What do you think?
