- Thread starter
- #21
pearlhouse
- Feb 17, 2011
- Brunswick, Ohio USA
- Canon mx892 & mx922
The newer European cartridges has a "5" as the first digit, and the newer American cartridges have a "2" as the first digit.
The PGI-520/CLI-521 cartridges I refilled using the German method did not start causing problems with ink flow until after maybe 5 or more refills. A sponge from a cut open cartridge clearly showed needle damage:
This is why I recommend using the top fill method for the newer cartridges. With the "zero clearance" plugs plus aluminium tape the sealing problems with the top fill method are non-existent IMO.
I thought I read about the "5" and "2" thing in another thread the other day.
I will admit there have been a couple of times the needle did not want to go all the way into the last chamber and I had to remove it and try again at a slightly different angle. So now I am very careful when inserting it that I am at right angles to the cart top and the side but with a slight upward angle (towards the bottom of the cart) but sometimes I still miss. I took all my needles which were blunt 20 gage held them to the side of a fine grinder wheel so as to sharpen them to a point just like a medical needle. Then I hand polished them on a honing stone to get them as sharp as possible. I can see where a blunt needle might try to push the sponge instead of piercing it. Do you know if you were using a blunt needle?? This is very interesting as I orginaly thought about this happening when I first started with the German method. When it comes down to it I may open up one of these carts Im having trouble with now to look at how the needle has pierced the sponge. Thats a great pic and think it should be posted somewhere where everyone might see what can happen.
