Doug Ransom
- Nov 27, 2017
- epson wf-4640, brother mfc-470
My Epson-WF-4640 died recently, toward the end of printing 1200 letters over a couple days.
I now have 4 1L bottles of BCH ink for epson with about 900ml left. (here is a link to the yellow https://www.bchtechnologies.com/ref...-yellow-pigment-ink-for-epson-ip1000y-ae.html ).
I asked BCH if I can use the ink on my bother this was their response:
I am not sure what the power cycle hack they suggest would do.
if I use the pigment ink on a dye printer, it will damage the printer?
What would be a reliable printer I could use this ink in, with available of auto-reset chips in refillable cartridges or even a CISS? Epson seems to be a poor choice.
The refillable cartridges I was using on the Epson came from a vendor who claimed the chips were auto-reset, but I don't think they were.
It is pigment ink for Epson. You can use it on Brother's pigment printer. However, you can't use it on dye Epson or dye Brother. Most of Brother printers are dye printer, so be careful. Make sure it is pigment printer first.
Also, if you really want to use it on a dye printer, put a little timer on the power outlet. Shut off the power and turn it back on once or twice a day. It's not suggested to use pigment in dye printer but this trick works.
