Can EPSON L475 do pigment ink ?
ogonzales
Epson L475
@Ink stained Fingers I've found this 2 for the moment:
504, not the 512 I need:
What do you think of this generic ink? It says UV on the package:
Sorry to disappoint you - you cannot just go by whatever is printed on the box, there are so many 'UV resistant' inks you can buy from China via Aliexpress, but they all are very weak performing inks when it comes to fading, just forget them all.
The 664 inks are used on the similar model range, only a few years earlier, as the 504 inks - combo printers - scanners for home/small office applications, the ink may be the same , but the top of the bottle is different, it is mechanically coded now that you cannot put yellow ink into the cyan tank, and that demands a different number for the ink. You should search in internet shops for the 512 ink in your country - or neighbouring countries from where you can easily import such stuff.
