qwertydude
- May 7, 2009
Personally I only really care that the ink flows to the heads properly, and doesn't cause clogs and flow issues. As long as the color is pretty consistent when I buy it I wouldn't mind buying small containers but large containers pool the ink so the color is consistent from refill to refill because your taking ink from the same "source" ie your large bottle. If there's a small color cast to the ink it's taken out by profiling anyways but it would be annoying to have to do profiles because your ink supplier changed their ink wholesaler especially without telling you. So I like to stick with large bottles since a pint of each color lasts me about a year. I'm about to transition to MIS ink from Stratitec bulk ink. Stratitec bulk ink works really well just needs a profiling, I do like their pigment black and will continue to use it since it is fairly inexpensive at $29.99 a pint and I find is less prone to clogging than Canon OEM especially since I mostly print photos so pigment black can sit unused for a while, but I use it to refill the printers at work which use a lot of pigment black, a refill every two weeks or so among 4 printers.
