This is off Datacolors' Help file
Start Here
Manufacturers Inks, Manufacturers Black and White Driver
This method uses the printer manufacturer's inks (or inks that are very similar), and the black and white printing method provided in the manufacturers printer driver. This method cannot use ICC profiles for black and white color control, though they can be used for black and white linearity control. Results can be quite good, though its possible to improve neutrality and linearity, especially on third party papers. Unfortunately there is a minimum of controls for adjusting results. This method does not provide a means to create cross-tints, offers no preview, and lacks other advanced options.
This is certainly a good place to start with the latest two-gray printers: Epson 2400/ 3800/ 4800/7 800/ 9800, any Canon iPF printer, or either width of HP Z3100. This list does not currently contain many smaller models; the new HP B9180 (and the larger Z2100 models) and the new Canon PRO9500, are not two-gray printer, so do not qualify for the category described above. Their color mode creates its light grays from Light Cyan, Light Magenta, and Yellow, as earlier Epson models did. This is why they have not been included in the list above.
Spyder3Print owners would typically use the color driver, not the black and white option, for more precise and controllable results, and described in the Color Driver sections below.
Manufacturers Inks, Manufacturers Color Driver **
This method uses the printer manufacturer's inks (or inks that are very similar), and the color printing method provided in the manufacturers printer driver. One reason this method is so popular is that it allows both color and black and white prints without changing inksets, and uses similar ICC-based processes for profiling, previewing, and controlling printing for both color and black and white. Results printing black and white through the color drivers can be very good, though for best results it requires special products such as Spyder3Print to improve neutrality and linearity. This method offers excellent controls for adjusting results; provides a means to create cross-tints, offers softproof preview, and many other advanced options.
This is an ideal method for black and white printing using the latest two-gray printers: Epson 2400/ 3800/ 4800/ 7800/ 9800, any Canon iPF printer, or either width of HP Z3100. This list does not currently contain many smaller models; the new HP B9180 (and the larger Z2100 models), are not two-gray printer, so do not qualify for the category described above; their B&W mode is fixed, single tone, neutrality defined by the paper involved. So these models offer no tintability, without using color mode. Their color mode creates its light grays from Light Cyan, Light Magenta, and Yellow, as earlier Epson models did. This is why have have not been included in the list above.
Spyder3Print will improve black and white output via the color driver to most all printers, but only offers gallery quality black and white for two gray printers, or printers fitted with special black and white inksets.
Manufacturers Inks, RIP Driver *
RIPs are third party drivers that offer direct control of each ink channel. This used to provide a great deal of necessary control for black and white printing. RIPs are becoming less necessary for black and white printing as the free printer drivers offer better dithering, improved linearity, and some of the special functions that only RIPs used to contain.
RIPs also offer convenient layout functions, but other applications now provide these capapabilities, so RIP usage is dropping at all printer sizes. Larger printers, where effective layout of multiple images or multiple copies is most important, are the area where RIPs are still most frequently used. Use of RIPs with manufacturers inks will become less and less common as driver development progress continues.
Spyder3Print can be used to measure and export files for use in linearizing and profiling RIPs for black and white printing; it even includes special export formats for creating QuadTone RIP (QTR) linearization and profiling data.
Non-ICC Black and White Inksets, RIP Driver *
RIPs still have advantages for controlling some black and white inksets, as they can access each ink channel. But this means complex settings, and is not a user friendly process. There are several types of black and white inksets. Some print only one tone of black and white, such as neutral, or sepia. Others offer tinting controls, so that they can be adjusted by special settings. The newest type of black and white inksets are designed in a manner that allows them to be controlled via the free drivers and ICC profiling controls, so the use of a RIP with these inks is no longer necessary.
Spyder3Print owners would choose an ICC Capable Black and White inkset, for the advantages noted in that section below.
ICC Capable Black and White Inksets, Manufacturers Color Driver **
This method offers richer grays than manufacturers inks by increasing the number of gray inks, but also limits the printer to only gray and tinted gray prints while these inks are installed. This method allows many of the ICC advantages of the category above. The available tints are limited to inkset's range. This method requires Spyder3Print 2.0, and ICC profilable inks
End Here
