Hi! My Artisan 837 will not recognized the cis in Window 8. Is there new chips out there that can be recognized? Or is there a way to reload the old firm ware? Thanks.
Thanks for replying. I installed the Epson driver directly from Epson. I am using Continuous Ink System from Print On A Dime. I brought the cis around Dec. 1st. I like to find out if newer chips are out that will solve my problems. Print On A Dime does not have the new chips yet.
The OS should not have anything to do with your chips not being recognized. Your printer's firmware does. I am not sure you can go back to an earlier one.
Print on a dime is not what I would call one of the Main Standard 3rd Party Companies out there. You might have to re tool with a modern CISS unit is you still want to use one or go with refillables coded for your 837.
PrecisionColors or Inkjetcarts if in the USA would be sure choices.
