DonC
- Jan 3, 2016
- Artisan 1430
I don't often print larger than letter size, but the last time I printed a full 11x14 it printed flawlessly. However, recently I tried to print a photo with roughly similar resolution cropped to 14x10 borderless on 14x11 paper. Each attempt the printer gets some way through and then hangs. The printing stops, the head goes back and forth then docks, and I get a generic error message "error, the printer couldn't print...". As well, the status monitor indicates that the connection to the printer has been lost as there is no ink level display.
Printing at "Best Photo" setting I get the error about 15% through; at "Photo" It happenes at about 25%; at
"Text and Image" it gets about 50% through. If I print the same photo at letter size it works fine.
The printer is set up via wireless
So far I have tried:
-Uninstall and reinstall driver pakage
-re-register printer on the network
-Switch from spooling to direct
-disable advanced printing features
-switch epsonnet port from LPR to RAW
-disable high speed printing
-Printing from a different program
I realize that the best solution might be to try via USB, but I'd like that to be a last resort.
Any suggestions would be most appreciated.
-Don
-Don
