andy1978
- Mar 25, 2025
- T2100
Thanks for your previous input!
I found the chips for T2100 cartridges on AliExpress for £35 per set, but with VAT and shipping, the total comes to £50 just for the chips. At this point, it's becoming less and less worth the hassle, especially considering that third-party cartridges in the UK cost around £100. Since those are pigment inks, I'm wondering if it's even worth bothering with refilling via syringes.
On the other hand, I looked into the Epson 3100X Megatank and went through all your previous comments on it. From what I understand, the best option would be to replace Epson’s original dye inks with Canon GI-53 dye inks.
I have a question about switching between dye and pigment inks. If I start using dye ink, do I need to fully empty the cartridges before switching to pigment, or can I mix them while printing? Is there a specific cleaning procedure, like flushing the printhead with a special solution, before switching to pigment ink?
Also, I’m still unsure about the actual difference in print quality between dye and pigment inks for photo printing. I know pigment ink is more durable and doesn’t fade as easily in sunlight, but is the difference that significant in real-world use?
I’m also considering the Canon TC-20 and using dye inks (GI-53) from the start instead of pigment. Since I’ll only be printing on 24” canvas rolls (no sheet feeding), this setup might make sense. But I’m not sure if it’s the right approach.
To be honest, I tend to get frustrated easily with finicky printers, and if the TC-20 gives me too much trouble, I might just throw it out the window (hopefully, it's heavy enough that I can’t lift it). Jokes aside, I’m still debating between the Canon TC-20 and Epson. I called a company in the UK today, and they said Epson produces better-looking prints than Canon. But I don’t need museum-grade Rembrandt reproductions—just good-quality prints.
Based on what Keith showed in his video, Canon doesn’t seem like a bad option. Maybe I should just order it on Amazon, test it for 30 days, and return it if it doesn’t work for me.
Yesterday, I received canvas samples from a company, ranging in thickness from 260 to 360 gsm (260, 280, 300, 350, 360 gsm). I’ve ordered a caliper on eBay to measure the exact thickness, as it provides accuracy down to 0.01 mm. I’ll check whether I can print on canvases up to 0.27–0.28 mm thick.
I watched a video from a woman in the U.S. who prints on the Epson T2100 (which is called the T2170 there, but it’s the same model). She prints 24-inch canvas rolls, around 300 gsm, without any issues and is very happy with both the printer and the print quality—whether on canvas or photo paper. She loads a full 30-meter roll of canvas, and it works flawlessly.
Interestingly, whenever I talk to companies about printing on canvas, they all shake their heads and say this printer is completely unsuitable for it. Yet, people are successfully printing on it and getting great results. It feels like a bit of a scam—everyone insists this printer is only for CAD and engineering prints, then tries to steer you toward a £5,000 printer instead of a £500–600 one. That’s just the reality of the market, unfortunatey.
