- Feb 24, 2005
- Location
- North of Boston, USA
- Canon i9900 (plus 5 spares)
With the printhead removed from the printer, hold it above a paper towel and use a soda straw to blow into the cyan ink pickup. Does any ink come out of the cyan nozzles? If it does, your print head isn't completely clogged and something should be printed on the nozzle check. Put the print head and carts back into the printer and retry the nozzle check (the printer will automatically run a long cleaning cycle because it knows that the print head has been removed). You might also want to try printing the extended nozzle check pattern (http://www.nifty-stuff.com/forum/viewtopic.php?pid=869#p869). If the cyan is still completely missing, I suspect that the problem may be electrical.
The first image that you posted showed that the problem was only happening on the right side of the print. A failure like this could be caused by a bad flex cable (that carry the signals from the mother board to the moving print carriage) or a loose connection on one of the flex cables. As the carriage moves, an intermittent connection in one of these cables could come and go at the same position. You might want to carefully inspect these cables to see if there is something obvious.
