ThrillaMozilla
- Jan 18, 2011
I suspect that the method of storage of ink may affect the presence of bubbles in supply lines. Air is more soluble in cold liquid than at room temperature. If you refrigerate your ink, it will gradually dissolve more air, which will very likely come out very slowly in the form of bubbles after the ink warms up. Gassing and degassing can be very slow, so your ink can remain supersaturated with air for a considerable time -- possibly hours to months.
If it were mine, I would allow the ink to come to room temperature (or maybe slightly higher) before refilling, and I would shake it vigorously in the bottle to promote equilibration. You might worry that this could make the problem worse, but that's really not thermodynamically possible unless you warm the ink to a still higher temperature.
Obviously, there are also other possible reasons for air bubbles, but if I had that problem, I would consider the possibility.
I've been gone for some time, and I don't know about the extent of the problem, or whether you all have solved it. But I'm guessing you haven't.
