A new project
Amazing the power of the electric motor!
Looked up the plane for historical info. Couple fun facts...
"The Ta 152H-1 was among the fastest piston-engined fighters of the war, with a top speed comparable to the twin-engined Dornier Do 335. It was capable of 755 kilometres per hour (469 mph) at 13,500 metres (44,300 ft) using the GM-1 nitrous oxide boost and 560 kilometres per hour (350 mph) at sea level using the MW 50 methanol-water boost.[7] It used the MW 50 system mainly for altitudes up to about 10,000 metres (33,000 ft) and the GM-1 system for higher altitudes, although both systems could be engaged at the same time. Kurt Tank was flying an unarmed Ta 152H in late 1944 to a meeting at the Focke-Wulf plant in Cottbus when ground controllers warned him of two P-51 Mustangs. The enemy aircraft appeared behind Tank, but he escaped by applying full power and engaging the MW 50 boost "until they were no more than two dots on the horizon"."
"The Ta 152 score at the end of the war was probably seven victories and four losses in air combat, although a degree of uncertainty about those numbers exists. Four victories were achieved by Josef Keil, from 1 March 1945 to 21 April 1945,[15] and at least three victories were achieved by Willi Reschke.[16] The Ta 152 was delivered to JG 301 on 27 January 1945 and the first Ta 152 mission against American bombers took place on 2 March 1945. There was no contact with the Americans because the 12 Ta 152s were forced to fend off repeated attacks by the Bf 109s of another German unit, as the shape of the Ta-152 was virtually unknown to other Jagdgeschwader. There were no losses, as the climbing ability and manoeuvrability of the Ta 152s enabled them to evade these attacks."
https://en.wikipedia.org/wiki/Focke-Wulf_Ta_152
I wonder if hot rodders and racers got the idea for nitrous boost from WWII air craft?
