nertog
Regensburg, Germany
Epson R3000 - PX720 - P50
I checked about 5 times the print setting - I printed with the rel. col. intent - via 2 different programs which create essentially the same output. Prints mentioned above earlier with the abs. col. intent by far don't deliver clean grays.
I'm not looking to small fluctuations - there is a print process on a paper - there is a scan process to create the profile - there is a 2nd print with this profile on the same paper - and I'm scanning this patch sheet 3 x to average it - there is plenty of room for statistical fluctuations.
I would give Argyll a try and use the "Spotread" command to do single measurements of patches. The output is Lab (D50) by default.
My starting point was the same as yours that the abs. col. intent renders grays as much neutral as it is possible , but I got irritated by the actual measurements
printing with the absolute intent and then remeasuring those printed patches should be correct.
and by the above referenced statement that the rel. col. intent prints the exact colors. The actual prints should show evidence for one or the other position.
I'll add measured gray values to the above table with the abs. col. intent printed.
Here is an update with measured values from a patch sheet printed with the same ArgyllCMS profile but with the abs. colorimetric rendering intent, all other parameters are the same - same inks, same paper, same printer and driver settings, same 1 day drying time , measurements with the M2 UV filter and D50. I'm scanning with the i1i0 robot arm averaging 3 scans to reduce read errors, I don't have ArgyllCMS installed.
The a-value stays pretty much the same across all measurements from from black to light gray, the b-value grows to almost -20 - to-19,17 - which is a strrong blue cast and there is nowhere a somewhat neutral gray in the measured values.
nertog
Regensburg, Germany
Hmmm...something must have gone wrong there. Troubleshooting:
1. The white point should have no ink printed for the relative intent, but there should be something printed when using absolute colorimetric (measurements seem to indicate so). Is this the case?
2. If 1 == true, does the white point look slightly yellowish or do the measurements correspond to the visual impression?
Yes, no ink - the measured whitepoint is L a b = 95,10 0,91 -6,53
No, the white point looks blueish gray as the values indicate - L a b = 91,33 0,82 -10,95
which is about twice the values of the rel. intent - 0,95 x 0,95 = 0,90 for the luminance and -6,5 x 2 is slightly more than -10,95.
Just imagine a perfect white paper - with L=100 and a and b = 0 , the driver would print exactly the white point value of the paper stored in the profile onto this sheet - exactly the value I measure with the rel col intent and which was used to create the profile for the white point parameter.
blue_lazer
Brother HL-L3290CDW
Sorry if this is a stupid question.
What spectrophotometer should I buy to use with ArgyllCMS for printer profiling?
I know the Colormunki Photo is a commonly used one. I did see this list of known working spectrophotometers. I'd guess monitor calibrators will not work as they don't have a light source.
Used is OK, I ideally want to spend less than $100 USD if possible. Are there any models I should be on the lookout for used listings, and any I should avoid?
aCuria
Canon 5070, Epson L10850
I had a problem with the CAP480 chart,
With the ES-2000 (aka i1Publish Pro 2), the chart is too big to scan...
It seems that the spectro needs to start on a white part of the paper, but when using the ruler from the ES-2000 it is not possible to start on a white section of the paper while also being able to get to the last patch
  • I was able to get it to work by resizing longer edge of the image to 90% of the original value, but is there a better way of doing this?
  • Profile and log attached, I loaded the profile into GamutVision but I do not know what to look for to figure out if it was done correctly
  • The plan is to wait a week before re-making the profile, what is a good way to store the print in the meantime? I just put it under a stack of other prints...
Edit: profile has to be renamed, I had to rename to txt to get it uploaded
  • Wed 09-13-2023 EpsonL18050_HpPremiumPlusSwellable_ES2000_1Hr.txt
  • log_Wed 09-13-2023 EpsonL18050_HpPremiumPlusSwellable_ES2000_1Hr.txt
Probably not many people with i1Pro2 spectro's, but I want to share some target sets for ArgyllCMS with you optimized for i1Pro2 reading board/guiders.
  • ArgyllCMS_800-patch_target_1xA4_for_i1Pro2.zip
  • ArgyllCMS_576-patch_target_13x18cm_Photo_card_for_i1Pro2_.zip
  • ArgyllCMS-504-patch_target_10x15cm_photo_card_for_I1Pro2.zip
