DonC
- Jan 3, 2016
- Artisan 1430
I'm using refillable carts with precision colors inks. I hadn't printed in about 2 weeks which is usually fine, I printed a full page photo that came out ok. The next morning I tried to print and got problems. The nozzle check showed almost no lines of Light Magenta or Cyan. Checked that carts were full, removed and reseated them a few times, removed the fill caps to help them vent a bit, ran cleaning cycles, no luck. Let it sit overnight and the nozzle check showed a few scattered lines. After another cleaning cycle nozzle check sows zero lines, as if the carts are not providing any ink.
Suggestions are most welcome.
Thanks
Thanks
