- Jan 18, 2010
- Residing in Wicklow Ireland
Well you got my attention now, because things don’t look too good for the cyan, but we may be able to bring it back from the dead..
3 years idle, are your Friggin serious and then you expect it to just start printing without a hitch, no wonder your complaining about clogs, sure if you spent that long in bed, how would you find walking without assistance.
You may get it to function properly, or you may not, but a new print head, if you can find one, is a very costly route to take, a new Canon Pro 10 might be a better option if it comes down to a funeral.
Now if you haven’t printed anything other than the nozzle check since your last good print, then that will help a lot, try removing all the carts and vigorously shake the lot of them for 20 seconds and then re-inset them back in the machine
Next thing to try is 1 deep head clean then let the printer sit for 30 minutes before doing a nozzle check, it is very important at this stage to see if any of the missing section in the cyan block reappears from your posted nozzle check.
Let’s work on that for now...
P.S. Removing the head to clean externally is not an option with this printer...
