Pro 1 Set up
Derek Bennett
Canon pro 1
When trying to set up my Pro 1 every thing seems to go fine up to the point that it asks to turn on printer, it then says printer is detected. after a few min it comes up as printer is not detected check the connection.
I have tried on 3 different PC and different USB cables
The printer seems to work fine,
I have installed a full set of OEM carts and after printing around 30 A4 prints the ink monitor is still showing all ink as full, is this correct?
Thanks for all your help
kdsdata
Calgary, AB Canada
Pro-100 & Brother-L8900
I have similar problems when I re-install my Pro-100 drivers via network, cable or wifi. The only install that works trouble-free is the downloaded Canon install file (not the Windows "add printer") and the direct USB cable connection. After the initial install, I can use the printer via netwok, cable or wifi, or USB.
