alexisD
- Mar 24, 2025
- Canon TS5150
I’m new here and just signed up because I’ve run into a printer issue that I can’t seem to fix. I’ve spent the last three hours researching and trying different solutions, but nothing has worked so far. Usually, I manage to solve my printer problems on my own, but this time, I’m really stuck.
I’d be super grateful if someone could help me out or maybe share a tiny little tip that could point me in the right direction. Any advice is really appreciated!
Any suggestions on what to try next? Would replacing the printhead be a necessary step at this point?
Thanks in advance everybody!
Kind regards
Alexis
Printer Model: Canon TS5150
Issue Description:
I've recently noticed that when printing images, dark stripes appear across the print. The problem persists even after performing multiple troubleshooting steps.What I've Tried So Far:
- Deep Clean & Printhead Alignment
- Performed deep cleaning via the printer software.
- Aligned the printheads both manually and automatically.
- No improvement in print quality.
- Nozzle Check Results:
- Black (BK): Looks fine.
- Yellow (Y) & Cyan (C): Show minor white streaks, but not significantly missing.
- Magenta (M): Appears normal.
- Physical Cleaning & Firmware Update:
- Cleaned the printhead manually with an alcohol tissue.
- Updated the firmware to the latest version.
- No visible changes in print quality.
- Paper & Print Settings:
- Tested different paper types (regular and photo paper).
- Changed print quality settings (standard & high quality) with no effect.
- Ink Levels:
- Cartridges are half full, and I’m using original Canon ink.
Additional Notes:
- The issue is mainly noticeable when printing images (not so much with text).
- The printer has printed around 306 pages in total.
- The streaks look like horizontal bands rather than missing ink areas.
Kind regards
Alexis
