Canon Cd Print Printer Printing Tray E - Pixma - Pro 9000
I had no problems downloading the CD Print Tool v7 from club myce without having to sign in or sign up. Here is a direct link: club.myce.com/attachments/f123/260341d1374410670-cd-print-enabler-newer-u-s-canon-printers-cd-printtool-v7.zip . Copy the link and paste it into your browser.
You find a direct link to the archived Damn Printer site here, provided by stratman in another thread: http://web.archive.org/web/20120102235022/http://damnprinter.com/
I tested the CD tool using a Canon MP540, and it actually is a light version of one of the service tools.
This is the program window:
And you have to choose a paper source like with a service tool:
If the printer has not entered service mode you get this error message, like with the service tools:
When a function is completed you get this message, like with the service tools:
The "Print" button in the first window prints the EEPROM info, exactly like the info from a service tool, and the "Print2" prints the service test print with an extended nozzle check, also known from the service tools. To change the region setting click the "Set Destination" drop-down menu and choose EUR and click Set. This is also known from the service tools programs. You could of course also use one of the service tools in stead of the CD tool, just make sure you don't click any unwanted functions. The CD tool was tested using a Win 8.1 64bit, so I guess it works with all windows versions from XP and up.
The procedure for entering service mode is found in the service manual for the printer, or at the archived Damn Printer site.
The procedure for entering service mode is not quite clear from the service manuals, but Tudor rewrote the instruction to make it more clear:
With the printer turned off, but connected to a power source:
-press and hold the cancel button (lower)
-press and hold the power button (higher) - now both buttons are pressed
-release the cancel button, then press it twice - now only the power button is pressed
-release the power button - the printer is now in Service mode
-start the software and press the "EEPROM" button in the Main-Print section of the software.
For the CD tool the Print button is the same as the EEPROM button in the service tools.
The number of times the Resume/cancel button should be pressed in step 3 is 2 times, for most printers, but some printers require the Resume /cancel button to be pressed 5 times. I have also seen a few posts mentioning 4 and 6 times. It is 5 times for the Canon Pro-100.
gah
Canon Pro9000 II
OK, I got my Pro9000 II converted to EUR, and it prints with MyImageGarden windows, but not MyImageGarden Mac.
Both have the option to design CDs, and when printing select "CD tray E".
From Windows, it prints on CDs, from Mac it only prints on paper.
(If there is a CD tray, it gets blink code 6, to close the door.)
I suppose it isn't so bad, but would be nice from Mac.
The Mac version prints a nice circle, about twice the size of a CD.
gah
Canon Pro9000 II
Seems that I have two Macbooks, one with OS X 10.12, and the other 11.7.
Running the same My Image Garden, but different drivers, the 10.12 works, and the 11.7 doesn't.
Also, in case anyone is interested, I have it through a Unix print spooler.
Communication is one way.
But when I install My Image Garden, it asks where I am, and I answer a European country.
gah
Canon Pro9000 II
Seems that "My Image Garden" is the newer version of Canon print software.
And the same version runs on both of my Macbooks.
Seems to always know about CDS, or maybe it is because it asks where
you are when you install it.
